Seco X-Tip Drill Redefines Holemaking with High-Feed Performance and Sustainable Design!
Seco Tools has introduced the X-Tip Drill, an innovative exchangeable tip drill engineered to deliver high-feed performance, versatility, and sustainability — setting new standards for modern holemaking. Designed for efficiency and adaptability, the X-Tip Drill combines speed, precision, and environmental responsibility to meet the evolving demands of today’s manufacturing environment.
At the core of the X-Tip Drill’s design is its exchangeable tip system, which eliminates the need for multiple solid carbide drills. Instead, users can rely on a single, robust drill body and easily replaceable carbide tips to handle various materials and depths. This modular approach not only simplifies tool management but also reduces tool inventory, setup time, and overall operational costs.
Seco’s high-feed geometry ensures faster cutting speeds and cleaner holes while minimizing machine downtime. The result is a drilling system that enhances productivity without compromising on quality. The combination of a hardened tool steel body and precision-ground carbide tips provides both the rigidity required for stable performance and the flexibility for quick, efficient tip changes. This translates into higher throughput, less waste, and optimized production cycles — key advantages for manufacturers focused on lean operations.
Sustainability is another cornerstone of the X-Tip Drill’s design philosophy. The recyclable carbide tips allow shops to maintain performance standards while reducing material waste, aligning with global goals for greener manufacturing. This focus on circular tool use not only reduces environmental impact but also supports cost efficiency through extended tool life and reduced consumption of raw materials.
According to Ricky Payling, global product manager for solid round tools drilling at Seco Tools, the X-Tip Drill is built to transform how shops approach high-feed drilling. “With the X-Tip Drill, we’ve built a tool that delivers high-feed drilling performance while keeping things flexible and efficient on the shop floor. The combination of a hardened tool steel body and precision-ground exchangeable carbide tips means you get the rigidity you need with the convenience of quick changeovers — less downtime, more productivity.”
Designed for universal application, the X-Tip Drill performs effectively across a broad range of materials, from steels and cast irons to non-ferrous metals. Its optimized chip evacuation and advanced coating options ensure reliable operation in both high-volume production environments and precision-driven industries such as aerospace, automotive, and general engineering.
In essence, the Seco X-Tip Drill represents a smarter, more sustainable approach to holemaking. By merging performance, flexibility, and environmental stewardship, Seco Tools continues to empower manufacturers to work faster, cleaner, and greener — achieving maximum efficiency without sacrificing precision or quality.
