Exair Chip Trapper rebuild kit restores coolant filtration efficiency and extends equipment life!
Exair Corporation has introduced a Chip Trapper lid rebuild kit designed to restore performance and maintain efficiency in its fluid filtration systems. The solution is aimed at helping manufacturers extend the life of existing equipment while ensuring optimal coolant performance in metalworking operations.
The Chip Trapper system itself is widely used for removing contaminants such as metal chips, swarf and shavings from used coolant and industrial liquids. By effectively separating solids from fluids, the system helps prolong coolant life, reduce waste and improve machining performance. Clean coolant is essential for maintaining cutting tool life, ensuring consistent surface finishes and preventing damage to machine components.
Over time, even robust systems like the Chip Trapper can experience a drop in performance due to wear in sealing components or chemical interactions between coolant and internal gaskets. While the system features a pneumatic vacuum design with no moving parts—making it inherently durable—seals and connections can degrade with prolonged use in harsh industrial environments.
To address this, Exair’s rebuild kit provides a simple and cost-effective way to restore older units to near-original performance. The kit includes replacement bulkhead fittings, quick-connect components and sealing gaskets that address the most common wear points affecting system efficiency. By replacing these key elements, users can eliminate leaks, restore suction performance and improve overall filtration effectiveness.
The rebuild kit also includes a detailed instruction label that guides users through proper operation and maintenance of the Chip Trapper system. This ensures that operators can quickly carry out maintenance procedures and maintain consistent system performance without requiring extensive technical expertise.
One of the key advantages of this solution is its focus on preventive maintenance. Rather than replacing the entire system, manufacturers can refurbish existing equipment at a fraction of the cost. This approach not only reduces capital expenditure but also minimizes downtime, allowing production processes to continue with minimal disruption.
The Chip Trapper lid rebuild kit is available for multiple system sizes, including 30-, 55- and 110-gallon units, making it suitable for a wide range of industrial applications. This flexibility ensures compatibility with different shop floor setups, from small machining operations to large-scale manufacturing facilities.
In addition to the lid rebuild kit, Exair offers a broader range of maintenance solutions, including rebuild kits for valves, atomizing nozzles and filter separators. These products support a comprehensive approach to maintaining fluid management systems, helping manufacturers improve operational reliability and reduce long-term maintenance costs.
As coolant management becomes increasingly important in modern machining environments, solutions like the Chip Trapper rebuild kit play a critical role in sustaining efficiency. By ensuring clean coolant circulation and reducing contamination, manufacturers can enhance machining accuracy, extend tool life and improve overall process stability.
Exair’s latest offering reinforces the importance of proactive maintenance in industrial operations. By enabling users to restore performance quickly and economically, the rebuild kit helps manufacturers maintain high productivity levels while optimizing the performance of their existing fluid filtration systems.
