Tungaloy expands Y-Pro Series with YCGT inserts for high-precision complex turning!
Tungaloy Corporation has expanded its Y-Pro Series with the introduction of YCGT inserts, designed to deliver consistent performance in complex turning operations such as profiling, undercutting and V-groove machining. The new inserts are engineered to enhance precision, stability and surface quality in demanding machining environments.
A key feature of the YCGT inserts is their 25-degree corner angle, which enables improved accessibility and accuracy when machining intricate geometries. This design allows operators to perform detailed profiling and undercutting operations while avoiding interference with adjacent features. As a result, the inserts are particularly well-suited for high-precision components and small, complex parts.
The Y-Pro Series is compatible with multitasking machines and automatic lathes, making it a versatile solution for modern manufacturing setups where multiple operations are often performed in a single machine cycle. This compatibility helps manufacturers streamline processes, reduce setup time and improve overall productivity.
One of the standout benefits of the YCGT inserts is their ability to achieve dimensional accuracy and edge quality comparable to grinding processes. This capability allows manufacturers to produce high-quality finished components directly through turning operations, reducing or even eliminating the need for secondary finishing steps.
The inserts are also equipped with specialized 3D chipbreaker geometry, which plays a critical role in maintaining process stability. Efficient chipbreaking and evacuation help prevent chip entanglement, reduce tool interference and ensure smooth machining, especially in complex operations where chip control can be challenging.
Material performance is another important aspect of the new inserts. The SH7025 grade has been developed to provide an optimal balance between wear resistance and toughness. This ensures consistent tool life even during extended machining cycles, making the inserts suitable for continuous production environments.
In addition to durability, the SH7025 grade contributes to improved surface finish quality. The inserts produce smooth surfaces with enhanced gloss, reducing the need for additional finishing operations and helping manufacturers save time and cost while maintaining high-quality standards.
As machining requirements become more demanding, particularly in industries such as aerospace, automotive and precision engineering, tooling solutions must deliver both accuracy and reliability. The expansion of the Y-Pro Series reflects Tungaloy’s focus on addressing these evolving needs by offering tools that combine advanced geometry, material performance and process stability.
With the introduction of YCGT inserts, Tungaloy provides manufacturers with a solution that enhances machining precision, improves chip control and supports efficient production of complex components, making it a valuable addition to modern turning operations.
