Seco launches BB732 boring bridges to improve stability and efficiency in deep-hole machining!
Thursday 26 March 2026, 9:53:12 AM
Seco Tools has introduced its BB732 boring bridges, a modular tooling solution engineered to enhance performance in deep-hole boring operations. Designed to work with Steadyline bars, the system focuses on delivering vibration-free machining, optimized coolant delivery and improved surface finish quality—key requirements in precision manufacturing environments.
The BB732 boring bridges are developed to support both roughing and finishing applications, eliminating the need for separate tooling setups. This dual capability helps manufacturers reduce tool inventory, simplify operations and minimize setup time, ultimately improving productivity on the shop floor.
A key feature of the system is its compatibility with Steadyline SM40 shell mill holders, supporting bore diameters ranging from 114 mm to 301 mm for roughing and up to 315 mm for finishing operations. This flexibility makes the BB732 suitable for a wide range of large-diameter machining applications commonly found in industries such as aerospace, energy and heavy engineering.
The tool design incorporates a conical-reinforced holder geometry, which provides high levels of static and dynamic rigidity. This structural strength is critical in deep-hole machining, where long tool overhangs can lead to deflection, chatter and poor surface finishes. By enhancing rigidity, the BB732 helps maintain dimensional accuracy and consistency even under demanding cutting conditions.
Another major advantage of the system is its integration with Steadyline vibration damping technology. This feature actively reduces vibration during machining, enabling stable cutting performance and higher precision. Reduced vibration not only improves surface finish quality but also extends tool life and reduces wear on machine components such as spindles and bearings.
Coolant management is another area where the BB732 system delivers significant benefits. The tooling is designed with optimized coolant channels that direct coolant flow precisely to the cutting edge. This targeted delivery helps improve chip evacuation, reduce heat buildup and maintain insert performance during extended machining cycles. Efficient chip control is particularly important in deep-hole applications, where chip accumulation can lead to tool damage or process instability.
The system also incorporates a built-in safety stopper to prevent block ejection caused by centrifugal forces during operation. This feature enhances operator safety, especially in high-speed machining environments where secure tool retention is critical.
According to Kavita Dandge, the BB732 boring bridges are specifically designed to work seamlessly with Steadyline bars, particularly the SM40 series, for large-diameter deep boring applications. She highlighted the importance of optimized coolant flow in improving chip control and maintaining cutting-edge temperature, both of which contribute to consistent machining performance.
As manufacturers continue to push for higher precision, improved efficiency and reduced downtime, tooling solutions like the BB732 boring bridges play a crucial role in enabling reliable deep-hole machining. By combining vibration damping, structural rigidity and efficient coolant delivery, Seco’s latest solution helps manufacturers achieve better productivity while maintaining high-quality machining results.
