Floyd Has Groovy New Small Turning Line
Sunday 30 June 2019, 12:00:00 AM
As specialists in the turned part and precision machining industry, Floyd Automatic Tooling has now introduced the new EVOCUT-Line parting system from Applitec. The completely new parting and grooving system from Swiss tooling experts Applitec incorporates a compact design, simplified insert changeovers and compatibility with platen type tooling configurations – everything to make the EVOCUT-Line the first choice tooling system for compact work envelopes such as in sliding head turning centres.
With performance, precision and rigidity a given, the EVOCUT-Line is available with the H Series Monobloc toolholder, the H Jet Series with an integrated through coolant supply and the HK, HK-RS, HUK and HM designation of parting-off blades. The EVOCUT Line meets the complete needs of turned parts manufacturers with the HK Series being a generic parting-off blade whereas the HK-RS incorporates a recess for sub-spindle access. Additionally, the HUK blades have been designed for upside-down parting and the HM is a short length modular blade system. The H-Series and H Jet Series of toolholders are available with a 10, 12, 16 and 20mm square shanks to accommodate everything from compact tool platens in sliding head turning centres through to more robust fixed head machine tooling platforms. Each of the toolholder and blade designations has been optimally designed for fast insert changes and inter-changeability in compact work envelopes and machines with platen type tool configurations. This ease of access is certain to reduce non-productive tool changeover times whilst enhancing the flexibility on machines with limited tool stations.
The EVOCUT-Line is offered with four insert widths of 1.5, 2, 2.5 and 3mm that are capable of machining up to a maximum 44mm depth of cut. These ET15, ET20, ET30 and ET40 designations are available with Applitec’s impressive U, J, T and A style geometries that improve speeds, feeds, material removal flow and surface finishes whilst catering to the specific characteristics of a complete variety of material types.
Applitec has an unparalleled reputation in the small turned parts industry and the new EVOCUT-Line is the next generation destined to further enhance productivity, tool life and performance for end-users. The respective insert dimensions and geometries are available with no fewer than six grades that include PVD and CVD coated inserts as well as uncoated grades for non-ferrous materials. The variety of grades and geometries make the EVOCUT-Line suitable for high-performance parting and grooving of everything from stainless steel, carbon and alloy steel through to titanium, aluminium alloys, copper, bronze, plastics and more. With a compact design and the option of high-pressure coolant delivery, the EVOCUT-Line from Floyd Automatic Tooling is a game changer for the turned parts industry.
