Marking a part is not enough.
Monday 6 July 2026, 10:42:34 AM
A barely readable code. A mark that fails inspection. Data that never reaches your system. Any one of these can break the traceability chain triggering recalls, customer non-conformities, or hours lost in root-cause analysis.
True traceability is not just about putting a mark on a part. It’s about guaranteeing that the mark is permanent, readable, compliant, and fully connected to your data – today and years from now.
To achieve this, three non-negotiable imperatives must work together:
𝗥𝗲𝗹𝗶𝗮𝗯𝗶𝗹𝗶𝘁𝘆: A permanent mark (laser, dot peen or scribing) combined with an automatic verification step that certifies both legibility and compliance with the standards you require (ISO 15415, ISO 16022, and others).
𝗗𝗮𝘁𝗮 𝗜𝗻𝘁𝗲𝗴𝗿𝗶𝘁𝘆: Zero breaks between the physical mark and your information system. Every piece of data carried by the code must be captured, validated, and stored automatically and securely.
𝗜𝗻𝘁𝗲𝗴𝗿𝗮𝘁𝗶𝗼𝗻: A solution that fits naturally into your existing production flow – whether on high-speed lines or as a standalone station for quality control, rework, or logistics – without slowing you down.
That’s exactly what we deliver: complete traceability systems that combine marking machines with intelligent reading and identification technology. The system doesn’t just create the mark. It verifies it in real time, reads it, and pushes the data where it needs to go.
From ultra-robust DataMatrix codes and multi-format reading (1D, QR, alphanumeric) to our SIC Factory Automation software and full VIN traceability solutions for automotive, we close the loop between the physical part and your digital records.
Because in the end, traceability is only as strong as its weakest link.
