Can physics-based machining cut cycle times in half?
By Clinton Perry
Reduce cycle times by up to 50%, setup cost by 20% and tooling cost by 11%… Productive Machines demonstrates how physics-based machining can make it happen.
MTDCNC’s Clinton Perry and Cristina Sesma of Productive Machines discuss SenseNC, a CAM plug-in that analyses NC code and machine behaviour and helps eliminate chatter and optimise toolpaths directly inside systems like Siemens NX and Mastercam. Using tap testing, the software builds a “fingerprint” of the machine and tool setup to identify stable cutting zones before machining begins.
The result is reduced vibration, improved surface finish, and more predictable machining without leaving the CAM environment.
Watch the latest Productive Machines webinar here to learn more.
