Mitsubishi Materials Expands MV9005 Grade with New Negative Inserts for High-Performance Superalloy Machining!
MITSUBISHI MATERIALS U.S.A. CORPORATION has expanded its cutting tool portfolio with the introduction of 36 new M-class negative inserts in its MV9005 grade, designed to deliver enhanced performance when machining nickel-based heat-resistant superalloys and other difficult-to-machine materials. The latest additions strengthen the company’s tooling range for manufacturers operating in demanding industries such as aerospace, energy, power generation, and high-performance engineering, where machining efficiency, tool life, and process stability are critical.
Nickel-based superalloys are among the most challenging materials to machine due to their exceptional strength, heat resistance, and ability to retain mechanical properties at elevated temperatures. While these characteristics make them ideal for applications such as turbine blades, aircraft engine components, and high-temperature industrial equipment, they also generate high cutting temperatures, increased tool wear, and significant machining forces. As a result, manufacturers require cutting tools capable of maintaining performance and dimensional accuracy under extreme operating conditions.
To address these challenges, Mitsubishi Materials has developed a new series of M-class negative inserts featuring redesigned chip breakers that deliver improved cutting stability and reliability. Compared with the previous generation, the new chip breaker geometry incorporates larger land and rake angles, enabling more consistent chip control and reducing cutting resistance during the machining of heat-resistant alloys. These design improvements help manufacturers achieve smoother cutting action while maintaining process stability during both roughing and semi-finishing operations.
The expanded lineup includes 36 new negative M-class inserts available in C, D, S, T, and V insert styles, providing greater flexibility across a wide range of machining applications. In addition to the negative inserts, the company has introduced larger positive insert sizes in the same configurations, allowing manufacturers to select the most suitable tooling solution for different machining requirements and workpiece geometries.
To further optimise machining performance, the inserts are offered with a choice of LS, MS, RS, and MA chip-breaker geometries. This broad selection enables users to match the cutting tool to specific machining conditions, material characteristics, cutting parameters, and production requirements. The availability of multiple chip-breaker options allows manufacturers to improve chip evacuation, reduce cutting forces, and achieve more stable machining across a variety of operations.
At the heart of the new insert design is a specially engineered high-hardness carbide substrate developed to withstand the extreme mechanical and thermal loads generated during high-speed machining of superalloys. The enhanced substrate helps minimise plastic deformation of the cutting edge, preserving tool geometry and maintaining consistent machining accuracy even under demanding cutting conditions. This increased resistance to deformation contributes directly to longer tool life and more predictable machining performance.
Complementing the advanced carbide substrate is a high-aluminium-content aluminium titanium nitride (AlTiN) coating, which has been specifically formulated to provide exceptional hardness and superior oxidation resistance at elevated temperatures. The coating acts as a protective barrier against abrasive wear and thermal degradation, enabling the inserts to maintain cutting performance for longer periods while reducing the frequency of tool changes. Improved wear resistance not only extends tool life but also contributes to lower tooling costs and increased machine productivity.
Recognising the challenges associated with machining nickel-based heat-resistant alloys, Mitsubishi Materials has also applied a surface-smoothing treatment to the inserts. This specialised treatment improves resistance to material adhesion and welding, a common issue encountered when machining high-temperature alloys. By reducing the tendency of workpiece material to adhere to the cutting edge, the inserts deliver cleaner cutting action, improved surface finish, and more consistent machining quality throughout extended production runs.
Another important innovation is the introduction of a newly developed bonding layer that significantly enhances adhesion between the AlTiN coating and the carbide substrate. Stronger coating adhesion improves the insert’s resistance to chipping and prevents premature coating separation during heavy-duty machining operations. This contributes to greater reliability, increased process stability, and longer usable tool life, particularly in demanding high-speed and high-temperature applications.
The expansion of the MV9005 grade reflects Mitsubishi Materials’ ongoing commitment to supporting manufacturers with advanced cutting tool technologies that improve machining efficiency and productivity. As industries continue to adopt stronger, lighter, and more heat-resistant materials for critical components, the demand for cutting tools capable of delivering consistent performance under extreme conditions continues to grow.
With the introduction of these new M-class negative inserts, Mitsubishi Materials provides manufacturers with a comprehensive tooling solution that combines advanced substrate technology, high-performance coatings, optimised chip control, and enhanced durability. The expanded MV9005 range is designed to help machining operations improve productivity, extend tool life, reduce downtime, and achieve greater process reliability when manufacturing components from some of the world’s most challenging engineering materials.
