TRUMPF will also display the compact and high-precision 5-axis TruLaser Cell 3000 for laser processing (laser cutting and welding) of small to medium-sized components in two or three dimensions, and for laser metal deposition projects. Also in the booth, the company will also show the TruArc Weld 1000 automated arc welding system for easy and affordable high-mix, low-volume production; the versatile, compact and fully equipped TruLaser Station 7000 fiber laser welding system; and a TruMark Station 5000 for high-performance 3D laser marking.
Laser Cutting Machine with New Fiber Laser at IMTS 2026At IMTS 2026, TRUMPF will demonstrate the TruLaser 1030 fiber, a laser cutting machine that’s easy to use and to automate, equipped with new fiber laser technology for more sustained power, longer life, and greater durability and reliability, designed for manufacturers requiring high-speed, precision 2D cutting of sheet metal.
Laser Processing at IMTS 2026TRUMPF will also show its compact and high-precision 5-axis TruLaser Cell 3000 for laser processing (laser cutting and welding) of small to medium-sized components in two or three dimensions, and for laser metal deposition projects.
Digital photographs in print-ready resolution are available to illustrate this press release. They may only be used for editorial purposes. Use is free of charge when credit is given as “Photo: TRUMPF.” Graphic editing – except for cropping the main subject – is prohibited. Additional photos can be accessed at the TRUMPF Media Pool.
