Adding to the list of industry leading CAM vendors joining the MTDCNC platform is SolidCAM UK Ltd. Regarded as leaders in integrated CAM software, SolidCAM UK Ltd is the UK and Ireland reseller of SolidCAM and InventorCAM suite of CAD/CAM software for manufacturing from SolidCAM.
The integrated solution runs directly inside SolidWorks or Autodesk Inventor, with seamless integration and full tool path associativity. With single-window integration, all machining operations can be defined and verified without leaving the parametric CAD assembly environment you’re used to.
Due to being scalable, SolidCAM grows as you grow, with packages for all CNC machine types and applications. Therefore the software supports all Milling and Turning functionality, with powerful support for advanced Mill-Turn machines including multi-turret and multi-spindle, and Swiss-Type including multi-channel synchronisation. SolidCAM provides powerful programming tools that are easy-to-learn and use, covering the full range of 4/5-Axis Simultaneous Mill-Turn machines.
SolidCAM is the only CAM with the unmatched, patented iMachining solution which can save you 70% and more in machining time compared to traditional CAM solutions, as well as extending tool life drastically therefore decreasing machine downtime. The technology is also available as an integrated plug-in for Siemens NX. iMachining’s patented Technology Wizard provides optimal speeds and feeds based on tool path, stock material, type of cutting tool and CNC machine specifications.
SolidCAM UK provides the complete spectrum of CAD/CAM services for UK industry such as support, installation, training and Post Processors. Owing to its Technology centre based in Dodworth, Barnsley, the company runs successful Total Manufacturing Solution ‘Learn & Lunch Workshops’ showcasing the best-in-class solutions, with live cutting demonstrations. To register your interest to attend one of their seminars, please visit: ow.ly/ZiEO50xVXTM.
Now that this fantastic company has joined the MTDCNC marketing platform, our viewers, readers and social followers will be able to get all the latest news, updates, videos and behind the scenes insights that make SolidCAM UK an industry leader.
