Fryer Lathes Provide High Rigidity for Large-Part Machining!
Fryer Machine Systems has introduced its Easy Turn Large Capacity (ET-LC) lathes, designed specifically for small-batch turning applications that demand the high rigidity required for machining large parts. These versatile machines combine the precision of CNC technology with the accessibility of manual controls, making them suitable for shops that need flexibility, reliability, and user-friendly operation.
The Fryer ET-LC series is engineered to provide operators with the ability to run both manual and semi-automatic operations seamlessly. The lathes feature two handwheels for manual control, allowing operators of all skill levels to use the machines regardless of CNC experience. The manual handles, provided for the cross slide and carriage, are supported by full digital readout (DRO) displays, giving operators accurate position feedback. The handles also include electronic stops and a chamfer mode for improved precision. Additionally, a joystick enables manual feed control, further enhancing operator flexibility.
To simplify workflows, Fryer has integrated its “Do One” cycles into the Easy Turn machines. This feature allows users to automatically execute one machining operation at a time, such as drilling, boring, or tapping holes, eliminating the need for complex manual setups. By mixing manual and semi-automatic operations, shops can optimize one-piece production and handle a wider variety of tasks without lengthy changeovers.
The ET-LC series is also equipped with Fryer’s intuitive Shop Turn conversational programming system. This system accelerates programming by providing interactive graphic screens and real-time simulations, reducing the learning curve for new users. For shops that require more advanced programming, the machines also support industry-standard G- and M-code and are compatible with all CAD/CAM systems. This dual capability ensures that the ET-LC lathes can adapt to a wide range of production requirements.
In terms of capacity, the Fryer ET-LC lathes offer centers ranging from 60 to 200 inches and spindle bores from 4 to 12 inches. These specifications allow the machines to be configured to customer requirements, with optional live tooling and C-axis contouring and indexing spindles available for added versatility. This makes the ET-LC line suitable for handling both large and complex components across industries such as aerospace, energy, and heavy equipment manufacturing.
The machines are built on a cast iron one-piece base, ensuring maximum rigidity and stability during heavy cutting operations. High-precision ballscrews and bearings contribute to the machine’s accuracy, which Fryer specifies at ±0.0002 inches. This robust construction not only enhances machining performance but also ensures long-term durability. To reinforce its confidence in the product, Fryer offers a two-year warranty on all Easy Turn lathes, underscoring their reliability and quality.
By combining manual accessibility with CNC precision, the Fryer ET-LC series offers shops the best of both worlds: flexibility for operators of varying skill levels and advanced features for complex machining. Its mix of durability, ease of use, and customization options makes it a valuable solution for manufacturers working with large, heavy parts where rigidity and accuracy are non-negotiable.
With the ET-LC line, Fryer Machine Systems continues to expand its reputation for delivering machines that are both innovative and practical, ensuring manufacturers have the tools they need to remain competitive in today’s demanding production environment.
