Custom carbide form tools for turning
Tuesday 5 May 2020, 1:18:39 PM
To allow users to reduce cycle times and cut production costs during series production on turning and turn-mill centres, Horn Cutting Tools has introduced customised carbide form inserts for machining diameters from 16 mm upwards. Based on its 117 tool system, the patented insert seat guarantees high concentricity and minimal axial runout as well as high repeatability of insert exchange to within microns.
Precision-ground cutting edges deliver high accuracy and surface quality. Financial savings are gained, as the option to exchange the insert leads to lower tool costs and reduced machine downtime. The internal coolant supply to both cutting edges via the round shank cools the contact zone and carries chips away efficiently.
Horn offers the tools in profile widths of 16 mm, 20 mm and 26 mm. Special profiles can be precision ground to suit a diverse range of applications, maximum profile depth being 17 mm. The insert coating is selected for each application and is available for material groups P, M, K and N. Round shanks with diameters of 16 mm, 20 mm and 25 mm in the A and E designs are standard. All variants have an internal coolant supply.
