Welding on a CNC Machine from Heller, amazing!
By Rowan Easter-Robinson
Tuesday 21 June 2022, 1:27:13 PM
Welding aluminium parts on a Heller HF 3500 APC CNC machine leaves Rowan from MTDCNC totally amazed. Oliver Kull from Heller shows us how this amazing technology works. Metal removal and welding all on the same machine from Heller, incredible! What a way to save time in your manufacturing process. Friction stir welding uses a non-consumable tool to heat, soften and then mechanically mix the materials around the joint to create a gas tight seal, especially useful in the food & beverage market where ingress of bacteria between joints is an issue. The joints can also be stronger than conventional welded joints and the process can even weld dissimilar materials together. Metal removal and welding all on one machine from Heller, who knew?
