![](https://cdn.mtdcnc.global/cnc/wp-content/uploads/2023/07/13142158/SHARKONE_JULY_23.jpg)
Milling Centre with Movable Column (SHARKone)
High-speed milling machine with mobile column and high dynamics that offer innovative solutions and state-of-the-art performances.…
View productThe FH550SX is a powerful, high-speed horizontal machining centre featuring an 8,000 RPM high-torque spindle, with an option of 15,000 RPM spindle, and a rapid feedrate of 60 m/min. This machine has dual ballscrew drive on the Y and Z axes, and a Meehanite cast iron base for improved rigidity.
2 MACHINES AVAILABLE ON SHORT DELIVERY:
FH5000S-i (BT40)
Pallet size – 550 x 550 mm
X-axis travel – 750 mm
Y-axis travel – 800 mm
Z-axis travel – 850 mm
Max. workpiece swing – 850 mm
Max. workpiece height – 1,000 mm
Max. work load on pallet – 800 kg
Spindle output torque 530 N.m
Spindle – BBT40 / 15,000 rpm / 303 N.m
ATC – 60 tools
Control – Fanuc
FH5500SX-i (BT50)
Spindle – BBT50 / 15,000 rpm / 530 N.m
ATC – 60 tools
Control – Fanuc
Both machines include:
Chip conveyor and filtration unit
