![](https://cdn.mtdcnc.global/cnc/wp-content/uploads/2023/07/13122043/ACTIVE_FIVE_PARPAS_JULY_23.jpg)
ACTIVE FIVE 2200 LINEAR – HIGH SPEED BRIDGE TYPE MILLING CENTRE
ACTIVE FIVE 2200 LINEAR – HIGH SPEED BRIDGE TYPE MILLING CENTRE Availability – short delivery Technical…
View productHigh-speed milling machine with mobile column and high dynamics that offer innovative solutions and state-of-the-art performances. The machine structures are engineered with the aid of powerful calculation and analysis software. In order to provide a high dynamic control for the machine, its structures are built using steel alloys that offer higher rigidity, on an equal mass basis, compared to conventional materials such as cast iron.
Technical specfication:
X-axis travel – 2,500 mm
Y-axis travel – 1,050 mm
Z-axis travel – 1,200 mm
Fixed table – 3,000 x 1,000 mm
Rapid feedrate – 40,000 mm/min
Spindle taper – ISO50 – DIN 69871
Max. spindle speed – 5,000 rpm
Max. spindle power – 30 kW
Max. torque – 400 Nm
ATC – 30 tools
Control – Heidenhain TNC640
Available on short delivery.
Learn more at http://www.leadercnc.co.uk/Shark-One.php
