Miraclean Tanks Offer Highly Configurable Cleaning Solutions for Evolving Manufacturing Needs at PMTS 2025!
At PMTS 2025, Miraclean is showcasing its flexible and customizable cleaning systems, which consist of individual ultrasonic or static tanks in a standard size that can be easily organized within a stainless-steel frame. These plug-and-play systems are designed to grow with changing applications, allowing manufacturers to add, subtract, or modify components as process needs evolve. The modular design makes it a versatile solution for manufacturers seeking adaptability and scalability in their cleaning processes.
Miraclean’s systems can be configured with a centralized feed and drain header or a chemistry-appropriate drain, offering options for PLC-controlled automation that advances process loads and controls various actions. Additional features include chemistry dosing, rinse quality control, HEPA filtration, and other tailored options to meet specific cleaning requirements and throughput goals.
The system being showcased at PMTS 2025 includes multiple stages, such as a load-unload system, ultrasonic clean, ultrasonic rinse, static rinse, and re-circulating hot air dry, all with PLC-controlled automation for enhanced process efficiency.
Miraclean also offers specialized solutions for applications that require setting up a passivation line. In addition, the company builds custom cleaning, passivating, penetrant application, and titanium anodizing process lines in both automated and manual configurations, while supplying water-based chemistries for various industrial applications. This adaptability positions Miraclean’s systems as a comprehensive solution for cleaning, passivation, and surface treatment in evolving manufacturing environments.
