Massive material removal or perfect finish? Starrag delivers both.
By Arthur Field
Accuracy, rigidity, and flawless surface finishes. That’s what people need in the semiconductor world to get good parts.
MTDCNC’s Arthur Field and Starrag’s Jim Stolo break down Starrag’s X-series machines that combine a rock-solid cast-iron base, precision scales, and high-speed HSK spindles to hit those demanding tolerances.
Add advanced thermal control and multilayer coolant filtration and you have a stable, protected, and predictable process. Tune in to learn how complex semiconductor parts are finished in minimal setups with smooth transitions, zero mismatch, and no hand finishing.
