In this Technical Corner video, Lee Kendall of Sandvik Coromant discusses their CoroCut QD. The system has over- and under- coolant system which cools the cutting zone for better chip control, extended tool life, and higher cutting data started from 2mm. Providing easy coolant connection with plug-and-play adapters, stated Mr Kendall
Geometries designed for good chip formation, high stability, and coolant access in combination with grades that provide excellent edge-line security in all materials make for inserts that excel in every parting-off operation.
This system is built with performance and reliability in mind with inserts for Cut-off (C) grooving (G) and turning (T) making the CoroCut QD system one of the biggest on the market.
