These drills from Hoffman Group are built for increased profitability & cost savings!
By Tom Skubala
Thursday 27 April 2023, 10:00:25 AM
How does the Master Steel MICRO drill from Hoffmann deliver such incredible savings? Tom Skubala of MTDCNC and Paul Walker of Hoffmann Group join the MTD Technical Corner to discuss the impressive drill that’s helped customers achieve high performance, amazing tool life, and cost savings of up to £40,000 a year! With feed rates of over 2 metres a minute in steels and over 500mm a minute in stainless steel, this drill is designed to deliver brilliant hole surface finish, ovality, and fantastic overlay along with optimum chip evacuation. If you want to achieve impressive mirrored finishes, 4 times more tool life, and faster feed rates, check out the Master Steel MICRO and Master FEED drill ranges from Hoffman Group.
[ID4118374670]
