Time savings, efficiency & stability: IEMCA Kid 80 short bar feeder from 1st MTA
By Giovanni Albanese
Tuesday 14 June 2022, 1:00:24 PM
In today’s episode of MTDCNC’s Technical Corner, we speak to Clive Leonard from 1st MTA for insight and advice on IEMCA bar feeders. Giovanni Albanese interviews Clive on the Kid 80 + automatic high-performance short bar feeder. As a Servo bar feeder, the Kid 80 + gives more control on bar feeder lengths, feeding speeds, and feeding forces while also offering easy-to-use operation. Using a hand-held control unit or a touch screen system, you simply need to set your component length or bar diameter. The Kid 80 + can load a maximum bar length of 1.6m depending on spindle length. Watch the video as Clive explains how to achieve 0.5 accuracy with the Kid 80 + and reduce bar change cycle time by half using the pre-load function! IEMCA offers a vast range of bar feeders, exceptional build quality, and a stable SIEMENS platform in conjunction with Industry 4.0. Get in touch with 1st MTA if you want to automate your lathes and remain competitive.
