High-precision machining of turbine blades with the LX 021 from Starrag
By Paul Jones
Monday 4 September 2023, 1:00:19 PM
You might not find another machine in the world that manufactures such complex components this quickly! Starrag’s Lee Scott and MTDCNC’s Paul Jones discuss the Starrag LX 021 – a machine with endless possibilities for turning, milling, and drilling when it comes to complex aerospace engine blades. Designed specifically for 5-axis machining to tight tolerances and a great surface finish, the LX021 with a 30,000 RPM milling spindle and 4,000 RPM main spindle is a compact solution for complete machining in one hit! Check out the full video for a demonstration of all the things that go into making the perfect part.
[ID4718154098]
