This lightweight hybrid clamping solution from 5th Axis has the same rigidity as hardened steel!
Tuesday 19 March 2024, 5:00:00 PM
What goes into making lightweight but durable vises that can withstand the pressure? The answer is a hybrid solution that uses a perfect mix of aluminium and hardened steel!
Using hardened steel in all the necessary places where forces are being put on the vise allows 5th Axis to cut weight but maintain the same strength required for maximum efficiency. Learn more in an exciting discussion between Tony Gunn of MTDCNC and Mat Evans of 5th Axis as they talk rigidity, precision, and confidence to run through the night!
