Cut cycle times on complex high-precision parts with the Spinner TTS triple-turret solution
By Lyndsey Vickers
If you’ve got complex high-precision parts and higher volume, this Spinner TTS machine is for you! Lyndsey Vickers of MTDCNC and Robin Buchsein of Spinner discuss the features and flexibility of a machine designed for greater accessibility. With three turrets and two spindles so close together, operators can easily set up for the next job. The machine offers a vibration damper with each turret to eliminate micro vibrations and offer a flawless finish. And the new SIEMENS control and Spinner multi-touch panel with monitoring capabilities makes this the perfect piece of technology for overnight running! Watch and learn more about cutting down cycle times on complex parts with a flexible setup of two turrets on one spindle and a third turret for the sub spindle.
[ID4451137915]
