Twin-Spindle Twin-Turret Turning Centre With Built In Automation From Leader CNC Technologies
Wednesday 21 July 2021, 1:21:16 PM
Paul and Gio recently visited Leader CNC Technologies to review the FFG DMC DL24TTGB twin-spindle, twin-turret turning centre designed for high productivity with a mirror image design of the headstocks and turrets, plus the added advantage of automatic gantry workpiece transfer from one spindle to the other, this machine enables continuous and simultaneous machining for completion of first and second operations within a single machine.
Where limited floor space is a factor, the integration of two 2-axis turret lathes into a single machine tool gives you the flexibility of having two turning centres, but in approximately 30 percent less floor area. The FFG DMC DL24TTGB is automation ready and can easily be paired with secondary loading systems loaders to enhance productivity and provide 24/7 capability. Higher productivity, reduction in cost per part and improved quality can all be positively affected by adding a turning centre with an additional spindle to your shop floor.
