Massive Gruppo Parpas Machines from Leader CNC Technologies
By Giovanni Albanese
Thursday 20 October 2022, 4:00:36 PM
The Gruppo Parpas Speedliner is a bridge type construction gantry style 5 axis high speed machining centre used mainly in the mould & die, automotive and aerospace sectors. This huge machine is 6M in “X”, 3.2M in “Y” and 1.4M in “Z”, with a monobloc structure, gantry moving saddle, full Linear motors and stationary workpiece. As Marco Valentni from Gruppo Parpas tells MTDCNC’s Gio, this machine has a unique thermal stability control system ensuring it stays between 18-30 degrees to maintain high accuracy levels, crucial for producing large high value parts. This machine has a Heidenhain 640 control but is also available with Siemens. Gruppo Parpas Patented Dronex system allows you check the geometry and squareness of the machine in a dynamic way taking only a couple of minutes to complete; saving huge amounts of machine downtime and maintaining accuracy. If you want to know more about this machine or the many others in the Gruppo Parpas range call Leader CNC Technologies now.
