HAIMER Mill – productive, efficient, balanced by design and available now
Wednesday 4 September 2019, 11:12:25 PM
The HAIMER Mill endmill is a universal tool that can be used in many materials, and with its submicron carbide grade it offers excellent impact strength and high T.R.S The h5 shank tolerance for highest runout accuracy Safe-Lock™ shank for pull out protection and productivity improvement also offers many benefits. WIth the HAIMER Mills latest PVD and AlTiN coating, this production workhorse offers maximum wear protection. Pre and post treatment of tool surfaces for optimized chip removal also aids market leading performance.
The HAIMER Mill’s unequal cutting edge end helix slitting for vibration reduced machining is offered in 2, 3, 4 and 5 cutting edges with different lengths of cut based on application requirements. The range has been designed with cutting edge design (sharp, chamfer or radius) for maximum flexibility.
Other advantages also include; Highest run-out accuracy (max. 5 µm, market comparison: 15 µm)
Accurate overall length tolerance (+/- 0,05 mm), thus tool measurement is not always necessary Diameter
tolerance h9
