Blum Novotest BG60 Bore Gauge review
Monday 13 August 2018, 12:00:00 AM
The BG60 bore gauge from Blum Novotest is a must have for any precision engineer producing accurate bores in any sector. The obvious application is engines but also HCU's in the Aerospace sector. The BG60 is an independent measuring device using the machine tool only for axis position and the Blum unit does the rest. A typical method of application is to take a pre measurement prior to a final finishing pass and is concluded by a final measurement. This is a closed loop process and requires no intervention from the machine operator.
