Halter Basic Pro Offers Competitive Entry-Level Automation Solution for Machine Tool Loading
Saturday 15 February 2025, 5:37:54 PM
As manufacturers strive to stay competitive in the global market, automatic loading and unloading of machine tools is becoming an essential capability. To meet this growing demand, Dutch company Halter CNC Automation has introduced the Halter Basic Pro, a cost-effective, entry-level automation solution designed to streamline machine tool operations and increase efficiency.
The Halter Basic Pro represents a breakthrough in automation technology. Featuring a six-axis industrial robot, this machine tending cell delivers high-tech performance while maintaining a competitive price point. Available in England, Wales, and Scotland through sole agent 1st Machine Tool Accessories, the Basic Pro is engineered for manufacturers seeking to modernize their operations without the complexity of advanced robotics systems.
One of the standout features of the Basic Pro is its user-friendly interface, powered by the manufacturer’s SmartControl touch-screen system. Even if a workpiece has never been handled before, operators can change over to a new production process in just a few minutes. The system requires no prior experience in robot programming, as the programming can occur while machining of the previous parts is underway—maximizing production output with minimal downtime.
The plug-and-play Halter Basic Pro is designed for flexibility, allowing it to be easily integrated into both new and existing machine setups, regardless of machine age or control type. This adaptability ensures that even older plants can benefit from the automation revolution. The system also incorporates a floor-level, 270-degree laser scanner to create a safety zone around the robot. The robot will slow down if the operator approaches, and will stop immediately if the safety light curtain is breached, ensuring maximum operator safety.
The double gripper mechanism on the Basic Pro offers adjustable air pressure supply and can accommodate either two or three fingers for holding both raw material and finished workpieces. Capable of handling workpieces ranging from 10mm to 135mm in diameter or square, the robot can lift up to 12kg, including the gripper head. The grid plate, which holds raw material and finished parts, is adjustable in height to suit different installations and can accommodate up to 188 workpieces if the part size is 20mm. As part sizes increase, the capacity reduces to 14 parts for workpieces measuring up to 135mm.
Halter CNC Automation has a proven track record in the field of robotic loading cells, with over 1,000 installations worldwide, serving a wide range of industries including CNC lathes, machining centers, deep hole drilling machines, grinders, and inspection equipment such as coordinate measuring machines. The company has built a solid reputation for delivering high-quality solutions that offer a return on investment (ROI) within a short time frame. Nearly 95% of customers in 25 countries, including several in the UK, report a ROI within 18 months, with some even seeing a return in as little as five months.
The Halter Basic Pro is an ideal solution for companies looking to improve productivity, reduce costs, and embrace automation without the need for complex systems or heavy upfront investment. For more information or to arrange a demonstration, contact 1st Machine Tool Accessories today.
