XYZ Machine Tools updates its RLX 780 lathe to broaden its appeal
Thursday 27 August 2020, 8:44:11 AM
With the arrival of the new RLX ProtoTRAK control, XYZ Machine Tools was able to offer large capacity turning with the ease of use of ProtoTRAK with its heavy-duty RLX 780 lathe. The machine, with its 3000 mm between centre distance and 780 mm swing over the bed, has proved extremely popular with customers from a range of industries, such as; rail, oil & gas and, general sub-contract. Having established itself as the lathe of choice for large capacity, low-to-medium volume and turning; XYZ Machine Tools has now introduced a range of options to further enhance the appeal of the RLX 780.
The first option, which will appeal particularly to the oil & gas sector, is the availability of a 180 mm spindle bore (160 mm standard). This larger bore diameter makes the machine ideal for turning 6” API pipe, which has a standard 168 mm outside diameter. For customers not familiar with the benefits of ProtoTRAK, XYZ Machine Tools has added the option of a Siemens 828D ShopTurn control. Customers specifying this control option will also benefit from an eight-station turret with live tooling using a 30 VDI connection.
“The RLX 780 has exceeded all of our sales forecasts, which we made prior to Covid-19. It has proved extremely popular across industry sectors where large capacity mixed with flexibility is required. These latest updates and options will extend its appeal as a cost-effective solution to turning large, long components, but with the flexibility to machine smaller parts when required,” says Nigel Atherton, Managing Director, XYZ Machine Tools.
The standard specification of the RLX 780 includes a 40 hp spindle with Yaskawa inverter drive that delivers infinitely variable speeds across two ranges of 20 – 417 revs/min and 580 – 1300 revs/min. Machine stability comes from its 8600 kg overall weight, with the one-piece solid ribbed cast base, with a 500 mm wide vee and flat bed, ensuring accuracy and longevity.
