EMO Visitors Will Be in Seventh Heaven on Victor CNC Stand
Monday 14 August 2017, 12:00:00 AM
At the EMO exhibition in Hannover from the 18th to 23rd September, Victor CNC will be introducing a host of exciting new machine tools and innovations from its Stand E08 in Hall 27. With seven machine tools on the booth, Victor CNC will use the event as a platform to launch the new Vcenter-P136 and the new Vturn-45/125CM alongside a number of established machines.
The new Vcenter-P136 vertical machining centre is available with Y-axis travel of 700mm, a powerful FANUC 0i-MF CNC control unit with a 15inch monitor, a robust 12,000rpm spindle powered by a T8/12000i high torque motor. Renowned for being a brand built upon quality, stability, rigid and performance, the new Vcenter-P136 takes these attributes a step further. The new addition to the company’s VMC line up is supplied with a CTS, oil skimmer and much more. This exciting development will appear alongside the renowned Vcenter-AX800 that has set a new standard in heavy duty machining.
At EMO, the Vcenter-AX800 will be shown with a new Heidenhain TNC-640 full 5-axis CNC control unit, component measuring system, table shower, automatic door operation and the KinematicsOpt system with calibrating ball. This very latest Heidenhain TNC-640 CNC control with comprehensive 5-axis features will also debut on the market leading Vcenter- AX350. Offering a spacious 350mm diameter tilting table with Roller cam drive, the robust Vcenter- AX350 guarantees high reliability without backlash for prolonged service life, precision and performance.
As a manufacturer that has earned an enviable reputation for its high performance turning centres, Victor CNC will take its standing as the benchmark to new heights at EMO. This position will be cemented by the launch of the new Vturn-45/125CM slant bed turning centre. Extending upon the qualities that have made the Vturn a household name in the heavy duty turning sector, the new Vturn-45/125CM brings all these qualities into a more compact unit with a Z-axis travel range of 1250mm. Smaller than the 2200, 3250 and 4250mm variants, the new Vturn-45/125CM packs the same heavy duty machining capabilities into a compact envelope for manufacturers with limited floor areas. With a belt driven spindle and GTP gearbox for the C-axis, the Vturn-45/125CM will also mark the arrival of touch screen features on its FANUC 0i-TF CNC control unit.
Alongside this new arrival will be the Vturn-NP16CM with its upgraded C-axis BMT-45 tooling turret that will incorporate a new 6000rpm milling spindle, high pressure coolant, a work feeding WF-E100/10P with turnover station and an extremely impressive Easyway EWR-03 robotic loading station. Whilst the Vturn-NP16CM will be highlighting the automation credentials of the Victor CNC brand, the VT-Q200T2Y2 will be further emphasising automated production and flexibility with its twin spindle and twin turret configuration with Y-axis and robotic part catcher.
The final machine of the EMO line-up will be the extended VT-A26 turning line. The new VT-A26LSB-Y will incorporate a 105mm Large Spindle Bore with a Fanuc Bi250S Spindle motor and YCM milling capability, a high quality Kitagawa BB-212 chuck and a 14bar high pressure coolant unit. If you can’t make it to Hannover to see these exciting new innovations, get in touch with Victor CNC and we’ll take you through what these innovations can bring to your business.
