Starrag Tooling – Perfectly Matched for the Ultimate Machining Performance
Monday 11 August 2025, 4:27:41 PM
Attention turbine blade manufacturers! If you’re looking for the ultimate combination of precision, tool life, and surface finish, Starrag’s solid carbide tooling offers advantages you simply won’t find from any other supplier.
Unlike many machine tool manufacturers who source their tooling from third parties, Starrag designs and manufactures its own cutting tools – built specifically to complement the performance of their machine tools. This unique approach means every Starrag tool is perfectly matched to the spindle, control, and kinematics of the machine it’s running on.
The result?
  • Best Machining Results – Tool geometry and material are optimised for the exact machining conditions Starrag machines deliver.
  • Extended Tool Life – Reduced wear through precision balancing, advanced coatings, and perfect tool-to-machine synergy.
  • Superior Surface Finish – Especially critical for aerospace turbine blades, where accuracy, repeatability, and finish quality are paramount.
By combining Starrag’s industry-leading machine tool technology with their application-specific solid carbide tooling, you get a complete, integrated solution that delivers the highest levels of productivity, accuracy, and part quality.
For manufacturers of turbine blades and other complex components, this means more than just efficient cutting – it’s about achieving consistent, repeatable excellence in every single part.
📅 See Starrag’s latest machine tool and tooling solutions at EMO 2025
