Zaytran Launches Xray-S-5800 Double-Rail Gripper for High-Load, High-Speed Automation!
Tuesday 17 February 2026, 3:33:58 PM
Zaytran Inc. has introduced the Xray-S-5800 robotic gripper, engineered to support large-part automation with high accelerations, heavy moment loads and faster transfer velocities. The new double-rail design is intended to increase throughput in demanding robotic applications where stability and reliability are critical.
As robotic systems handle increasingly larger and heavier components, end-of-arm tooling must withstand significant dynamic forces. The Xray-S-5800 addresses these requirements with a gripping force of 1,300 pounds per jaw, ensuring secure part retention during rapid movement and multi-axis positioning.
A newly developed CDA bronze-based synchronizing system enhances the durability of the gripper’s precision mechanism. This material choice is designed to extend service life, reduce wear and maintain consistent performance under high-load conditions, contributing to lower maintenance needs and improved uptime.
The gripper’s dual machine-tool bearing rails provide structural reinforcement, enabling it to sustain side and moment loads generated during multi-G acceleration and deceleration cycles. This design increases rigidity and minimizes deflection, helping maintain alignment and positioning accuracy when transferring large components between workstations.
By combining high gripping force with enhanced load-bearing capability, the Xray-S-5800 supports higher robot velocities without compromising part stability. The result is improved cycle times and greater production efficiency in large-part automation environments.
With the launch of the Xray-S-5800, Zaytran expands its portfolio of heavy-duty robotic gripping solutions tailored to modern, high-throughput manufacturing systems.
