YG-1 i-ONE exchangeable drills and tool steel holders allow for fast changeover speed
YG-1’s new i-ONE system of exchangeable micro-grain carbide drill inserts and tool steel holders with coolant channels offer the advantage of a solid carbide drill combined with the flexibility of steel bodies
The drill inserts feature micro-grain carbide core for strength and advanced multilayered H-coating for hot hardness and minimal wear. They also features optimized point geometry for centering and smoother cutting and ground negative land on cutting edge for extended cutting life
The system’s nickel-plated tool steel holder features a premium tool steel shaft optimized to resist corrosion and wear and ensure body clearance and a flute shape for smooth chip evacuation. It also includes a Torx Plus® Screw for reliable insert seating and stability at the full range of speeds and coolant holes to dissipate heat in and evacuate chips from the cutting zone
The drills come in various insert sizes, and tool steel holders are available in 3xD, 5xD, and 8xD depths and in ODs from.393 in. to 1.328 in. and Ø10mm to Ø33.73mm.
YG-1 | www.yg1.ca
