3-Dimensional Services Group Expands Manufacturing Capabilities with 60-kW Fiber Laser Installation!
Tuesday 7 July 2026, 8:21:45 AM
The 3-Dimensional Services Group has strengthened its advanced manufacturing capabilities with the installation of a new 60-kW fiber laser cutting system at its facility in Rochester Hills, Michigan. The investment reflects the company’s continued commitment to expanding its production capacity, enhancing precision manufacturing and meeting the growing demand for large-format, high-performance laser cutting solutions. By integrating one of the industry’s most powerful fiber laser systems into its operations, the company aims to improve productivity while supporting customers across a wide range of industrial sectors requiring complex fabrication and low-volume production.
The newly installed Gweike 60-kW fiber laser has been designed to handle demanding industrial cutting applications with exceptional speed and accuracy. Equipped with a large cutting area measuring 16 by 32 feet, the system enables the processing of oversized components that are commonly used in heavy fabrication, structural steel manufacturing and large industrial assemblies. Its expansive working envelope provides manufacturers with greater flexibility to process large workpieces efficiently while reducing the need for multiple setups and secondary handling operations.
One of the key capabilities of the new laser system is its ability to cut materials up to 4 inches thick while producing precise 45-degree bevel cuts. This advanced cutting performance allows manufacturers to prepare components for welding and assembly with minimal additional machining, helping reduce production time and improve overall manufacturing efficiency. The combination of high laser power and precision cutting technology also enables cleaner edges, tighter dimensional accuracy and improved surface quality across a wide range of material thicknesses.
The 60-kW fiber laser has been engineered to support heavy-duty manufacturing applications, including thick-plate processing, structural steel fabrication, industrial equipment manufacturing and other high-volume production requirements. Its high-powered cutting capability enables faster processing speeds while maintaining consistent quality, allowing manufacturers to increase throughput without compromising precision. The system is particularly well suited for industries requiring large, complex fabricated components, where productivity, reliability and repeatable performance are critical.
The installation further enhances the comprehensive manufacturing capabilities offered by the 3-Dimensional Services Group. The company specializes in the production of production-intent prototypes and low-volume manufacturing, providing customers with end-to-end engineering and manufacturing services. Its capabilities include tool design and manufacturing, precision machining, metal forming, metal bending, laser cutting and final assembly, enabling customers to move efficiently from product development to production within a single manufacturing partner.
By investing in advanced laser cutting technology, the company continues to strengthen its ability to support increasingly complex manufacturing projects while responding to evolving customer requirements. The addition of the 60-kW fiber laser not only expands production capacity but also enhances flexibility for processing larger and thicker materials with greater precision and efficiency. As manufacturers continue to demand faster turnaround times, improved quality and integrated manufacturing services, the investment positions the 3-Dimensional Services Group to deliver enhanced value across a broad range of industrial applications while reinforcing its commitment to advanced manufacturing excellence.
