Weighing in at 97,000 lbs, the C 1800H heavy-duty CNC lathe from ROMI
Romi says its C 1800H heavy-duty CNC lathe from is ideal for machining large steel parts and components. Weighing in at 97,000 lbs, the lathe features a distance between centers from 157″ to 394″, a 47″ swing over cross slide and a maximum weight capacity between centers of 66,100 lbs at 50 rpm. The bed width and height are 55″ and 30″, respectively.
Romi’s C 1800H is part of the company’s C series heavy-duty flatbed CNC lathes. Each model is built with monoblock cast iron beds with hardened and ground guideways for optimum rigidity, accuracy and performance. The C1800H features a 114 hp main motor and a geared A2-20″ headstock with Timken precision bearings. According to the company, it has a robust tailstock with thrust force monitoring and compensation system.
All critical components used to build Romi machine tools are designed and built in-house, which the company says leads to complete control and manufacturing quality assurance. Romi says its machine tools are designed and manufactured based on extensive customer research and feedback.
