VOMAT UBF filtration systems are the answer for hard to filter materials
The VOMAT UBF concept is a vacuum band filter equipped to handle a wide variety of sludge materials, such as ceramic, HSS, brass, aluminum oxide, disc abrasion and more.
It operates with oil as well as water-miscible coolants. In some instances and if necessary it can be combined with a VOMAT fine filtration unit.
It is currently available in three sizes with the following filtration capacities: 110 Gal. /Min., 264 Gal. /Min. and 528 Gal. /Min. As with all VOMAT designs, the UBF system has a small foot print for its capacity.
