Tungaloy Unveils New STV Insert for Precision Internal Grooving and Profiling in Complex, Narrow Areas!
Friday 8 November 2024, 12:16:54 PM
Tungaloy-NTK America Inc. has expanded its TungShortCut internal grooving tool line with the introduction of the STV-type insert, designed to improve precision in internal profiling and the machining of complex shapes or narrow areas. This addition complements the series’ existing offerings, such as the DGS-type insert for grooving and the DTR-type for full-radius applications. The new STV insert, measuring 9 mm in length, features a 35-degree corner angle that allows for efficient wall and bottom machining in confined spaces where traditional V-shaped inserts may struggle.
The TungShortCut toolholders accommodate small diameters, supporting machining as narrow as 12 mm, making the tool highly effective for small-diameter internal groove profiling. The STV insert includes a JS-style chipbreaker that optimizes chip control, especially in profiling operations with variable depth cuts, enhancing efficiency. Additionally, the PVD-coated AH725 grade used in these inserts provides durability across a variety of workpiece materials, ensuring consistent, long-lasting performance.
The expanded TungShortCut line with the STV insert is ideal for industries requiring high-precision internal profiling and complex shaping in restricted spaces, driving productivity and reliability in tasks that were previously more challenging.
