Tungaloy Introduces Advanced TungBoreMini Toolholder for Improved Chip Evacuation and Efficiency!
Monday 16 December 2024, 11:37:59 AM
Tungaloy Corp. has expanded its TungBoreMini series with the addition of a new toolholder designed for a minimum machining diameter of 8 mm (0.315″). This enhancement extends the versatility of the tool line, making it well-suited for machining small and complex components. The TungBoreMini series is a multifunctional tooling solution capable of performing both drilling and OD/ID turning operations without the need for frequent tool changes, saving valuable time and reducing tooling costs for manufacturers.
The newly introduced 8-mm diameter toolholder broadens the existing range of diameters, which now spans from 8 mm to 32 mm. This addition allows manufacturers to handle more detailed and intricate machining tasks, improving efficiency and enabling high-precision work. Its ability to address the needs of complex parts ensures that users can achieve better operational outcomes and enhanced productivity.
A standout feature of the TungBoreMini series is its optimized chipbreaker, which delivers exceptional chip control across varying cutting depths. This design maintains cutting stability, ensuring consistent performance even during challenging machining operations. Alongside the chipbreaker, the toolholder’s advanced internal coolant supply systemfeatures two dedicated outlets for effective cooling and chip evacuation. One outlet is positioned near the cutting edge for precise cooling, while the other directs coolant axially to enhance chip removal and minimize interference.
By combining advanced features like the optimized chipbreaker and dual-outlet coolant system, the TungBoreMini series helps manufacturers achieve better tool stability, improved chip management, and reduced downtime. These benefits result in significant time savings and cost efficiency, making it an ideal solution for modern machining environments.
Tungaloy’s commitment to innovation is reflected in the expanded TungBoreMini lineup, which continues to provide manufacturers with reliable, high-performance tools designed to meet the demands of today’s precision machining challenges.
