TRUMPF Launches High-Power TruLaser Tube 7000 to Boost Productivity and Flexibility!
TRUMPF has introduced its latest TruLaser Tube 7000 laser tube cutting machine, designed to deliver significantly higher productivity, flexibility, and precision for manufacturers. Built for the North American market, the new system combines high laser power with intelligent automation to meet the growing demand for efficient and versatile tube processing solutions.
At the core of the TruLaser Tube 7000 is a powerful nine-kilowatt laser, enabling it to process thicker materials at remarkable speeds. The machine uses nitrogen as its cutting gas, allowing for clean, high-quality cuts even in demanding applications. For example, when cutting 0.375-inch-thick mild steel, the system can deliver productivity gains of up to 30 percent and increase feed rates by as much as 150 percent. These improvements translate directly into higher throughput and lower cost per part, making it a strong value proposition for manufacturers handling complex or high-volume workloads.
One of the standout features of the new system is its enhanced flexibility. The machine supports a significantly larger outer circle of up to 11.4 inches, allowing it to process a wide range of tube sizes and profiles. This includes square tubes up to 8 by 8 inches, round tubes with diameters of up to 10.75 inches, and rectangular profiles with dimensions up to 10 by 6 inches. At the same time, it maintains high-speed precision when processing smaller tubes, enabling manufacturers to handle diverse production requirements on a single platform.
To ensure consistent part quality, TRUMPF has integrated advanced assistance systems into the machine. The enhanced ScanLine function evaluates raw material using light section sensors to detect deviations, while the new Quality Pilot feature intelligently determines when and how often measurements are required. This reduces unnecessary inspection cycles and improves efficiency. Additionally, the ObserveLine Comfort system checks whether scrap has been fully removed after cutting, enhancing process reliability and reducing the need for manual rework.
The machine also introduces ObserveLine Edge technology, which enables seamless processing of pre-punched tubes and profiles. By automatically detecting existing contours and adapting the cutting program, the system provides greater flexibility, particularly when working with pre-processed or purchased semi-finished components.
Beyond hardware capabilities, the TruLaser Tube 7000 is fully integrated into TRUMPF’s digital ecosystem. Features such as Condition Monitoring allow real-time analysis of machine data, providing early warnings for wear or deviations and helping prevent unplanned downtime. The inclusion of automated loading systems like LoadMaster Tube further enhances operational efficiency by reducing manual intervention and supporting seamless integration into smart factory environments.
Designed for industries such as machine building, construction, automotive, and agricultural equipment, the TruLaser Tube 7000 offers manufacturers the ability to produce both small and large batch sizes efficiently. As part of TRUMPF’s “local-for-local” strategy, the machine will also be produced in the United States, reinforcing the company’s commitment to serving regional customers with advanced, high-performance manufacturing solutions.
Overall, the launch of the TruLaser Tube 7000 highlights TRUMPF’s continued focus on combining power, precision, and digital intelligence to help manufacturers stay competitive in an increasingly dynamic production landscape.
