TJ Davies Launches New Coolant Tubes and Wrenches for HSK Tool Holders!
Wednesday 10 September 2025, 4:55:42 PM
TJ Davies Co., Inc., a trusted name in precision tooling components, has introduced a new line of coolant tubes and wrenches engineered specifically for HSK tool holders. Designed with durability, performance, and user convenience in mind, these new products add to the company’s robust portfolio of high-quality tooling solutions and reflect its ongoing commitment to supporting modern machining operations.
The coolant tubes are manufactured from 8620 alloy steel, a material known for its excellent toughness, wear resistance, and ability to withstand demanding machining environments. Each tube is fully machined in-house at TJ Davies’ facilities, ensuring consistent quality control and adherence to tight tolerances. To further enhance reliability and service life, the coolant tubes feature two identical seals that allow for slight angular movement. This design improves sealing performance, supports operational flexibility, and reduces the risk of premature wear or leakage, thereby maintaining coolant delivery accuracy over long production runs.
TJ Davies has made the coolant tubes available across a broad range of tool holder sizes, from HSK 25 to HSK 125. This versatility makes the product line suitable for a wide variety of machining applications, from small, intricate workpieces to heavy-duty operations requiring robust tool clamping and cooling performance. For every coolant tube size, the company also offers a corresponding wrench designed to simplify installation and removal. By providing paired solutions, TJ Davies helps machine shops ensure compatibility, streamline setup, and minimize downtime.
Recognizing the importance of responsiveness in today’s fast-paced manufacturing environment, TJ Davies has built inventory across all sizes of coolant tubes and wrenches. Standard sizes are in stock and ready for immediate shipment, with same-day delivery available for orders placed by 3:00 PM (EST). This quick-turn capability supports customers who face urgent tooling needs, unexpected breakdowns, or tight production schedules, helping them keep operations running smoothly.
In addition to the new coolant tubes and wrenches, TJ Davies continues to manufacture its well-regarded line of retention knobs and pull studs. With more than 500 varieties available—many of them stocked for immediate delivery—the company supports a wide spectrum of CNC machines, including models that are older or considered obsolete. By offering custom manufacturing options, TJ Davies helps customers extend the life of their equipment, ensuring that even legacy machines can continue to perform effectively in modern production environments.
This launch of coolant tubes and wrenches reinforces TJ Davies’ reputation as a comprehensive supplier of high-quality machine tool accessories. From its advanced manufacturing processes to its customer-focused service model, the company consistently delivers solutions that balance durability, precision, and practicality.
For machine shops seeking tooling solutions that combine proven material performance with thoughtful engineering, TJ Davies’ new line of coolant tubes and wrenches for HSK tool holders represents a valuable addition. Backed by the company’s extensive product range and commitment to customer satisfaction, these new components help manufacturers enhance tool holder performance, reduce downtime, and achieve greater productivity in competitive machining markets.
