TaeguTec Introduces T-HYCHUCK Hydraulic Chucks for Superior Precision and Stability!
Wednesday 20 August 2025, 7:34:10 AM
TaeguTec has unveiled T-HYCHUCK, its latest line of hydraulic chucks engineered to deliver higher clamping force and enhanced machining precision. This next-generation chuck system is designed to provide manufacturers with greater stability and accuracy across a wide range of machining operations.
The T-HYCHUCK series builds on TaeguTec’s proven expertise in toolholding technology, offering a substantial performance upgrade over its previous models. By combining high-precision clamping with a stronger gripping force, the new line ensures improved machining accuracy while minimizing vibration and tool slippage. This translates into longer tool life, smoother surface finishes, and more consistent results in demanding production environments.
One of the major advantages of the T-HYCHUCK system is its versatility. The chucks are available in general, slim, and extension models, enabling machinists to select the most suitable configuration for specific applications, including deep cavity milling, tight spaces, and complex part geometries.
Importantly, the new hydraulic chuck line has been designed for seamless compatibility with TaeguTec’s existing hydraulic chuck portfolio. As a result, manufacturers can transition smoothly without changing their existing setups. Over time, the T-HYCHUCK will gradually replace the current product range, ensuring a steady and efficient upgrade path for customers.
By enhancing both clamping stability and machining precision, TaeguTec’s T-HYCHUCK series underscores the company’s commitment to delivering innovative solutions that improve productivity, reduce downtime, and strengthen process reliability in modern machine shops.
