Supertec Machinery Launches PMGII-150CNC ID/OD Grinder to Revolutionize Setup Efficiency!
Wednesday 8 January 2025, 10:06:44 AM
Supertec Machinery has introduced the PMGII-150CNC, a state-of-the-art turret-type multi-spindle ID/OD grinder designed to optimize setup efficiency and improve productivity in grinding operations. Engineered to handle complex and large-scale tasks, the PMGII-150CNC is ideal for industries that demand precision and versatility in machining.
This advanced grinder boasts a between-centers distance of 1,500 mm (60 inches) and a working diameter capacity of 380 mm (15 inches), making it one of the most robust turret-type ID/OD grinders in the market. The machine is equipped with a 20-inch plunge-type OD wheel, a 16-inch angle-head OD wheel, and an optional high-speed ID spindle, enabling a broad spectrum of grinding capabilities. This versatility allows operators to handle a wide range of tasks without needing multiple setups.
A standout feature of the PMGII-150CNC is its innovative turret design, which integrates three spindles into a single machine. This configuration significantly reduces setup times and cycle durations, enabling seamless transitions between different grinding operations. Additionally, the compact design helps conserve valuable shop floor space by eliminating the need for multiple machines for different processes.
The machine is powered by a Mitsubishi M80 control system integrated with Supertec’s proprietary i-Grind conversational software, which caters to operators of all skill levels. For users who require traditional G- and M-code programming, the machine also offers an optional FANUC Oi-TC control. These user-friendly systems enhance operational precision and programming efficiency, making the PMGII-150CNC suitable for both beginner programmers and seasoned professionals.
With its advanced capabilities, the PMGII-150CNC is an excellent choice for industries such as aerospace, automotive, and precision manufacturing. The combination of high performance, reduced setup times, and space-saving design positions this grinder as a valuable asset for companies looking to streamline operations and achieve greater productivity. Supertec Machinery’s latest innovation sets a new standard in ID/OD grinding technology, ensuring exceptional results across a wide range of applications.
