Star SU Introduces Chamfer Hob for Burr-Free, High-Precision Gear Manufacturing!
Saturday 3 January 2026, 12:39:42 PM
Star SU has developed a specialized chamfer hob designed to streamline gear manufacturing by producing burr-free chamfers in a single, seamless operation. Engineered to function like a conventional hobbing tool, the chamfer hob eliminates the need for secondary finishing processes, helping manufacturers improve productivity, consistency, and overall gear quality.
Unlike traditional chamfering methods that often require additional tools or manual deburring, the Star SU chamfer hob integrates chamfering directly into the gear cutting cycle. This approach ensures high-precision chamfers with clean edges, reducing the risk of burr-related assembly issues and improving downstream process reliability. By combining cutting and chamfering into one step, manufacturers can significantly shorten cycle times and simplify process planning.
The chamfer hob is custom-tailored to the specific gear geometry, allowing it to deliver maximum accuracy and repeatability for each application. This customization ensures that chamfer size, angle, and consistency are optimized for the gear design, even when working with complex profiles or tight tolerance requirements. As a result, the tool supports stable processes and predictable results in high-volume production environments.
Star SU’s chamfer hob is also designed to address some of the most common and challenging chamfering scenarios in gear manufacturing. These include shaft gears with shoulder interference, ring gears with fixture-related access limitations, and gears with inclined lateral surfaces. By accounting for these constraints during tool design, the chamfer hob enables reliable chamfering where conventional solutions may struggle or require multiple operations.
In addition to precision and process integration, the chamfer hob offers long tool life and low cost per part, making it well suited for large-scale production. The robust design minimizes wear while maintaining consistent cutting performance over extended runs, helping reduce tooling costs and unplanned downtime.
With its ability to deliver burr-free chamfers, accommodate complex gear geometries, and support efficient high-volume manufacturing, the Star SU chamfer hob provides gear manufacturers with a practical solution to enhance quality, reduce finishing steps, and improve overall production efficiency.
