SMW Autoblok’s 40-mm Workpiece Positioning System Mini designed to reduce setup times
SMW Autoblok has introduced the 40-mm Workpiece Positioning System (WPS) Mini. The company says it is well-suited for small workpieces that require quick part changeover. The workholding system is designed with an emphasis on flexibility and speed, and it can reduce setup time by 90%, according to SMW Autoblok. It is designed to be interchangeable with all types of industry stationary workholding systems.
The WPS Mini features manual zero point clamping that attaches directly to the workpiece, provides maximum holding force of 25 kN and repeatability of less than 0.005 mm. Single, quick actuation is designed to provide rapid open and closing of the module with a 270° rotation.
The system is Proofline-sealed against dirt and swarf. It can be used with standard WPS and APS modules with special clamping pins and adapters that are case-hardened with corrosion-resistant coating.
The WPS Mini is part of SMW Autoblok’s full line of WPS clamping modules, which are offered in 60-, 80- and 160-mm heights. All modules can be mounted on a t-slotted table or grid plate manufactured with highly tempered quality steel with a specialized coating to protect against rust and contaminants.
