Siemens Unveils Optimize MyProgramming/3D Scanner Software to Boost CNC Programming Efficiency and Precision!
Wednesday 29 October 2025, 12:17:08 PM
Siemens continues to drive innovation in digital manufacturing with the launch of its Optimize MyProgramming/3D Scanner — a groundbreaking software solution designed to transform CNC programming by integrating 3D analysis directly into the control system. This control-integrated tool enables operators to work more efficiently, achieve higher precision, and significantly reduce programming time, setting a new benchmark for intelligent machining operations.
Part of the Siemens Xcelerator portfolio, Optimize MyProgramming/3D Scanner combines advanced 3D scanning technologies with real-time programming capabilities within the Sinumerik Operate interface. This seamless integration allows users to generate and refine CNC programs directly at the machine, eliminating the traditional gap between CAD data and programming. By automatically transferring geometric information from 3D CAD models into machining programs, the software minimizes manual data entry, reduces the risk of errors, and accelerates setup times on the shop floor.
In modern manufacturing environments, where precision and speed are essential, this solution provides a distinct advantage. Operators can now visualize and analyze 3D part geometries, make instant programming adjustments, and validate machining strategies directly at the CNC control. The result is a faster, more intuitive workflow that reduces downtime and enhances both accuracy and productivity.
A standout feature of the software is its intelligent suggestion engine, which offers customized recommendations for machining strategies based on the geometric characteristics of each part. By optimizing toolpaths and parameters in real time, the system not only boosts productivity but also ensures consistent quality and repeatability in manufacturing. This level of automation helps bridge the skill gap in CNC programming, empowering less-experienced operators to achieve expert-level results.
The Optimize MyProgramming/3D Scanner also supports digital twin technology through Siemens’ Run MyVirtual Machine platform. This allows manufacturers to simulate machining processes, test programming strategies, and identify potential issues before actual production—saving both time and material costs. For physical machines, the software is available under a perpetual license, while digital twin users can add it as an optional module for virtual validation.
Siemens emphasizes that this new solution is more than just a software upgrade—it’s a step forward in smart manufacturing. With full support from experienced Siemens service partners, manufacturers can access consulting and implementation assistance to integrate the system seamlessly into existing production environments. This ensures that both small workshops and large-scale facilities can benefit from faster programming cycles, improved machine utilization, and optimized overall equipment efficiency (OEE).
By merging 3D visualization, real-time data integration, and intelligent automation, Siemens’ Optimize MyProgramming/3D Scanner marks a significant advancement in CNC technology. It reflects Siemens’ ongoing commitment to enhancing the precision, flexibility, and digital connectivity of machine tool operations. As industries continue to embrace data-driven manufacturing, tools like this are paving the way for a future where CNC programming is faster, smarter, and more intuitive than ever before.
