Semicollaborative System Engineered for Lathe Automation
Monday 17 October 2022, 9:37:46 AM
Methods Machine Tools, a supplier of high-precision CNC machine tools and automation in North America, releases the Turn-Assist 200i and 270i from RoboJob as its first end-to-end standard automation system for Nakamura-Tome turning centers.
A semicollaborative system engineered for lathe automation, Turn-Assist is designed to be implemented and run by operators of any skill level. With a simple tablet-style HMI and standard Ethernet IP interface, shops can successfully change over from one part to another within minutes, the company says.
“By pairing the Turn-Assist from RoboJob with Nakamura-Tome, we have created a unique automation solution for high-mix/low-volume or mid-volume with frequent changeovers on round workpieces often associated with Nakamura lathes,” says Zach Spencer, Methods’ automation manager.
Turn-Assist features an open-floor setup and area sensors to maximize operator safety and accessibility. Meanwhile, a pre-programmable FANUC robot loads blanks and unloads finished parts from the stocking table. Options are available to enable the robot to process shafts, rotate parts and interface with a bar feeder.
Additionally, the integrated, automatic air blow nozzle on the dual three-jaw gripper enables the robot to discard chips and coolant away from the workholding — further streamlining operations without any manual intervention.
“In introducing Turn-Assist for Nakamura-Tome, machine owners gain a user-friendly, reliable automation system to increase efficiency and output on day one without any operator upskilling requirements,” adds Sergio Tondato, Methods’ Nakamura-Tome product manager.
Original article from Modern Machine Shop
