Scientific Cutting Tools launches advanced coating programs to boost machining performance!
Scientific Cutting Tools has introduced two advanced coating solutions—Zirc (ZrCN) and Onyx DLC (ta-C)—expanding its capabilities in machining non-ferrous materials and high-performance threading applications. The new coatings are designed to address common machining challenges such as tool wear, material adhesion and inconsistent surface finishes.
The Onyx DLC (diamond-like carbon) coating has been developed for superior performance in machining aluminum and other non-ferrous materials. Known for its ultra-low friction and high surface hardness, the coating significantly reduces built-up edge—a common issue that can degrade tool life and affect part quality. It is now available across a broad range of SCT’s solid carbide thread mills, including UN and metric single-profile thread mills, straight flute designs and 15-degree helical thread mills.
By minimizing friction at the cutting interface, the Onyx DLC coating enables smoother chip flow and reduces heat generation. This leads to improved tool longevity, more consistent threading performance and enhanced surface finish quality, particularly in high-speed and high-volume machining environments.
In parallel, SCT has expanded the application of its Zirc (ZrCN) coating across its hydraulic porting tool range. These tools are designed to meet SAE J1926 and AS5202 specifications and are available in both reamer-style and pilotless configurations. The Zirc coating improves resistance to adhesion and wear, making it particularly effective for machining aluminum components such as manifolds and valve bodies used in hydraulic systems.
A key benefit of the Zirc coating is its ability to enhance surface finish while maintaining dimensional accuracy, which is critical in applications where sealing performance and reliability are essential. By reducing material buildup on the cutting edge, it also helps maintain consistent machining performance over extended production runs.
According to company leadership, different materials generate unique wear patterns during machining, requiring tailored tooling solutions. By introducing these advanced coatings, SCT aims to provide machinists with more precise options for matching tool performance to specific material behaviors.
Overall, the new coating programs are designed to optimize machining processes by improving chip control, reducing heat and minimizing tool wear. This translates into higher productivity, reduced downtime and better part quality for manufacturers working with non-ferrous materials and precision threading applications.
