Schwanog’s Insertable Tooling System Revolutionizes Tool Changeovers and Boosts Productivity!
Thursday 8 May 2025, 8:18:43 AM
At Eastec 2025, Schwanog introduced its innovative insertable tooling systems, designed to eliminate the need for presetting tools during changeovers. This breakthrough technology allows for tool changeovers to be performed directly in the machine, significantly reducing machine downtime and enhancing productivity and process safety.
Schwanog’s insertable tooling systems are engineered to offer high quality and efficiency in the production of precision parts across industries such as medical, automotive, and aerospace. This versatile system is applicable to a variety of cutting operations, including OD/ID grooving, thread whirling, thread milling, single-point threading, turning, milling, broaching, shaving, and skiving. Additionally, it supports polygon turning and form drilling, making it adaptable to a wide range of manufacturing needs.
One of the standout features of Schwanog’s system is its compatibility with a variety of machine types. The insertable tooling can be used on machines ranging from Swiss-types and conventional lathes to multispindle automatic lathes, rotary transfer machines, horizontal machining centers (HMCs), and vertical machining centers (VMCs). This broad applicability makes the system an attractive solution for manufacturers with diverse machinery setups, offering flexibility and efficiency in any production environment.
Traditionally, tool changeovers often require presetting outside of the machine, which can lead to extended downtime and delays in production. Schwanog’s insertable tooling system eliminates this step by enabling tool changes to occur directly within the machine. This capability not only reduces machine downtime but also increases process safety by minimizing the risk of human error during tool setup.
By allowing operators to make quick, in-machine tool changeovers, manufacturers can achieve faster turnaround times and greater consistency in their operations. The result is a significant increase in productivity while maintaining high levels of precision and quality.
The ability to change tools directly within the machine means that Schwanog’s system provides a more efficient workflow, allowing for faster production cycles and less time spent on tool changes. This increased productivity translates to better overall efficiency, especially in environments where rapid changeovers are necessary. Additionally, the elimination of presetting reduces the potential for tooling errors, further enhancing process safety and ensuring a higher level of reliability in manufacturing.
In summary, Schwanog’s insertable tooling system offers manufacturers a game-changing solution by eliminating the need for tool presetting and facilitating direct machine tool changeovers. This technology not only reduces downtime but also increases productivity and process safety, making it an invaluable tool for industries demanding precision and efficiency in their operations.
