Revolutionising Precision Machining: HIWIN Torque Motor Rotary Tables
In response to the escalating demands for complexity, precision, and efficiency in the machine tool industry, the integration of general processing machines with rotary tables has become imperative. Enter the HIWIN Torque Motor Rotary Table, boasting high transmission efficiency and rapid acceleration and deceleration, thereby enhancing production efficiency and elevating processing quality.
Equipped with a water-cooled torque motor, high rigidity and precision bearings, absolute encoder, and robust clamping system, the HIWIN Torque Motor Rotary Table outshines its mechanical counterparts with its attributes of speed, torque, and precision. Perfectly suited for diverse precision machining industries, it offers unparalleled performance.
Distinguished by its direct drive transmission structure, this rotary table dispenses with traditional mechanical components like worm gears and roller cams. This innovation minimizes mechanical wear, resulting in zero backlash and heightened machining accuracy, thus elevating stability.
The integration of a Torque Motor Rotary Table upgrades existing machining equipment to versatile 3+1-axis, 4-axis, or 5-axis machines, facilitating one-time clamp machining and significantly enhancing efficiency and productivity.
Primarily employed in the machine tool industry for milling, drilling, and grinding operations, HIWIN Torque Motor Rotary Tables ensure precise workpiece positioning, leading to accurate machining and reduced processing time. In the automation sector, they play a pivotal role in assembly, inspection, and testing tasks, facilitating precise component positioning and orientation for efficient production processes.
With rapid acceleration and deceleration capabilities, these tables excel in high-speed operations and swift positioning, making them invaluable in electronics manufacturing and 3D printing industries. Furthermore, their IP68 water protection and high rotational speed make them indispensable for micro-part machining in the semiconductor industry, particularly in Electrical Discharge Machining (EDM) applications.
The HIWIN Torque Motor Rotary Tables epitomise the epitome of precision machining, revolutionising industries with their unparalleled performance and versatility.
Original source Machine Tools World
