RAFI – RAMO Autonomous Industrial Pushbuttons and Switches with M12 Connection
Tuesday 6 August 2019, 4:26:33 PM
The RAMO range includes pushbuttons, emergency stop switches, selectors and key switches, M12 connector LEDs, and USB 3.0 and RJ45 ports on the front panel.
Complex wiring and dedicated hermetic packages tend to increase the cost of installing pushbuttons, selector and emergency stop switches, or signaling devices in industrial applications. The RAMO range includes pushbuttons, emergency stop, selector and key switches and M12 signaling LEDs, as well as USB 3.0 and RJ45 ports on the front panel.
RAMO control components and indicator lights provide a highly cost-effective and easy-to-install solution. These stand-alone RAFI products do not need an extra box or special seal. They are plug-and-play, which reduces wiring costs and errors. Their installation does not require any special technical skills. With their waterproof one-piece housing and circular M12 connection, pushbuttons, emergency stop, selector and key switches, and LED RAMO LEDs can be installed via standard slot openings of 22.3 and larger. 30.3 mm without additional shutter. The RAMO EDGE 90 ° mounting bracket simplifies the installation of standalone RAMO components. It is suitable for profiled rails of 40 mm.
The RAMO EDGE mounting bracket facilitates the installation of control elements on 40 mm profile rails
Depending on the type of component, the installation varies between 30.2 mm (RAMO 22) and 36.4 mm (RAMO 30). For space-constrained applications, these products are available with M12 connectors with right-angle cable outlets. By rotating them 135 °, these guarantee a high assembly density. The RAMO range has been designed with a view to homogeneity and compatibility with the appearance and dimensions of the RAFIX FS + range of control devices to allow the free combination of control components of both ranges. The pushbuttons are offered with illuminated signs available in many different colors, and with a normally open contact. The pushbuttons can be individually labeled via the FLEXLAB system. In addition to the push buttons,
About RAFI
Founded in 1900, the RAFI group designs and produces electromechanical components (push buttons, switches), operator systems (touch screens, keyboards), electronic components and human-machine communication systems. RAFI products are used in more than 30 sectors: medical equipment, mechanical engineering, road and rail vehicles, household appliances, telecommunications … RAFI operates worldwide. The group employs around 2,500 people at ten sites in Europe, China and the United States. Its headquarters are in Berg (Baden-Württemberg, Germany).
Inquire about this item
